Are you experiencing a DirectDraw error when launching Age of Empires? This issue is common among players using modern Windows systems. DirectDraw is a legacy graphics API that some older games rely on, and compatibility problems may arise on newer versions of Windows. In this guide, we will explain how to fix DirectDraw errors and how to download and install DirectX 12.
Causes of DirectDraw Errors in Age of Empires
The DirectDraw error typically occurs due to:- Incompatibility between the game and modern Windows versions.
- Missing or outdated DirectX files.
- Graphics driver issues.
- Display settings that are not optimized for the game.
Fixing DirectDraw Errors
Method 1: Enable Compatibility Mode
- Right-click on the Age of Empires shortcut or .exe file.
- Select Properties.
- Navigate to the Compatibility tab.
- Check Run this program in compatibility mode for: and select an older version of Windows (e.g., Windows XP or Windows 7).
- Click Apply and OK.
- Launch the game and check if the issue is resolved.
Method 2: Disable Hardware Acceleration
- Press Windows + R, type dxdiag, and hit Enter.
- Go to the Display tab.
- Check if DirectDraw Acceleration is enabled.
- If enabled, try disabling hardware acceleration in your graphics settings.
Method 3: Update Graphics Drivers
- Press Windows + X and select Device Manager.
- Expand Display adapters.
- Right-click on your graphics card and choose Update driver.
- Select Search automatically for drivers.
- Restart your computer and try launching the game again.
Method 4: Install or Repair DirectX
Since DirectDraw is part of DirectX, ensuring that you have the correct version is crucial.Downloading and Installing DirectX 12
- Visit the Microsoft DirectX Download Page.
- Click Download and run the installer.
- Follow the on-screen instructions to complete the installation.
Method 5: Modify Registry Settings (Advanced Users Only)
- Press Windows + R, type regedit, and hit Enter.
- Navigate to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\DirectDraw - Locate and modify any settings related to display resolution and acceleration.
- Exit the Registry Editor and restart your PC.
Conclusion
By following these steps, you should be able to resolve DirectDraw errors and enjoy Age of Empires without issues. Updating DirectX, enabling compatibility mode, and keeping your graphics drivers up to date are essential for smooth gameplay. If the issue persists, consider using a virtual machine or an emulator to run the game in a legacy Windows environment.
